Permanently Closing An Air Vent In The House - HVAC - DIY Chatroom Home Improvement Forum
Old 05-14-2008, 10:30 AM   #1
Permanently closing an air vent in the house
I am currently doing a small home renovation project and there maybe a need to permanently close an air vent in the living room (there are two and I only need one as the room is small). I am thinking of taking out the grill and just installing a pre-cut cardboard in place of the air vent and shut it permanently.
Has anyone ever done something like this before? Any negative impact to the Heat/AC system as now there is less venting of the Heat/AC air than maybe what the system was designed for. There are still plenty of other air vents which will be left open though (more than 12).
cougar91 is offline   Reply With Quote
Old 05-14-2008, 04:18 PM   #2
Registered User
Termite's Avatar
It depends on your system's design...Ducts, AC unit size, etc. It will affect the static pressure for sure, but that may or may not be a good thing. If your AC unit was already oversized for your duct system, closing 1/12th of it off could be a bad thing. If it was perfectly sized, I doubt you'll see too much negative effect.
Old 05-17-2008, 06:29 AM   #3
oops, did I do that!
In any room you should have two vents...a supply, positive pressure...and a return, negative pressure. If the vent you are going to block off is the return, negative pressure, you may be creating problems.
8 Ball is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 09:04 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
Corrosion problem in vent stack. sgbotsford HVAC 2 12-01-2007 02:47 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 05:42 PM
