Old 03-04-2010, 09:23 AM   #1
Question
Periodic shutoff
My Lennox Elite periodically shuts off or won't start back up. I have replaced the thermostat. I have it set at 68-70. some mornings I wake up and it is 60 or below and no furnace. If I turn the thermostat down and then back to 68-70 it will turn back on. That is why I started with replacing the thermostat but that wasn't it. Any help would be greatly appreciated.
wilbert36 is offline   Reply With Quote
Old 03-04-2010, 11:25 AM   #2
Chaos Engineer
Big N8's Avatar
Periodic shutoff
You may want to take a picture on the furnace and also a picture of the control board inside. this may give us a better idea of what you have. Also post the model of the furnce but if you don't know then pics should be good.
Big N8 is offline   Reply With Quote
Old 03-04-2010, 04:23 PM   #3
An old Tradesmen
Periodic shutoff
The control board will flash an error code.
But. You have to go and look at it before you turn the stat down and back up. That rests the code.
Gas shutoff for fireplace WishIWasAPlumbr Plumbing 13 03-07-2010 11:36 PM
shutoff valves all leaking hohadcr Plumbing 1 08-01-2009 07:38 AM
Meter Shutoff KE2KB Plumbing 14 03-18-2009 08:29 AM
Water shutoff questions robwallis Plumbing 1 02-09-2009 04:22 PM
Need your help installing a shutoff valve! HELP! HELP! kevp Plumbing 6 12-21-2008 12:36 AM
