Per Pictures - Does This Waterheater Roof Vent Modification Matter? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-01-2012, 11:20 PM   #1
MB1
Per Pictures - Does this waterheater roof vent modification matter?
Hello, I am trying to figure out whether this gas water heater vent cap and/or roof jack/pipe flashing modified by my roofer matters and needs to be corrected, and if so, where can I find the correct parts? I’ve search the internet but can’t located the cap or full assembly.
Please see attached photos. You'll notice the supports on the flue were snipped to remove the original pipe flashing, leaving it very wobbley, then the new flashing was installed to attach the the new mushroom style cap. I also think the old one may have had a collar.
- 2003 Mobilehome, waterheater located in carport
- I have had hot water since the modification 30+ days ago.
Reason I am concerned:
  • Cap appears to have been engineered for a particular reason, and I noticed that the cap is different for similar mobiles by same manufacturer when the water heater is located inside the house.
  • Codes – Almost all the mobiles in my neighborhood, even those 20-30 years old, are like this if heater is located in carport.
  • The inner & outer pipe I think were meant to be a unit
  • Potential performance, Energy efficiency, fire hazard, so implications?
Thanks for taking the time to read my post and appreciate the insight and help.
Per Pictures - Does this waterheater roof vent modification matter?-after1_wh_small.jpg   Per Pictures - Does this waterheater roof vent modification matter?-before1_wh.jpg
MB1 is offline   Reply With Quote
Old 02-02-2012, 06:52 AM   #2
what kind of hot water tank is it? picture of tank wold help alot
harleyrider is offline   Reply With Quote
Old 02-02-2012, 01:36 PM   #3
MB1
Waterheater Type
It is a Rheem Glass Warrior 21I40T, about 9 years old. Will get a picture of it up later.
Old 02-02-2012, 02:01 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 148
Looks dangerous as heck to me. If it does not get a proper draft thru it then it will burn dirty and definitely produce CO carbon monoxide and could spill it out the front of the burner into your house. It also should extend about 3 feet thru the roof. The idiot roofer you had should be thrown off the roof for being such a hacker and irresponsible IMO.
Rheem should be able to advise you what they want and I would phone them and explain what you have and what the problem is.
Old 02-02-2012, 02:56 PM   #5
MB1
Thanks Yuri. And you probably recall this is the roofer who threw out the engineered crown on my furnace and replaced it with the wrong one. I would love to get your opinion on this thread in roofing which is related to what I think is incorrect venting of all my bathroom fans: Need advice-what needs correcting? What does replace all vents, metal flashings mean? (Maybe I should have split up my roofing post and posted it here instead?)
I actually called Rheem yesterday, gave them my serial number, and talked to someone who said that if it was working ok, then the cap I have should be ok. I explained I wanted to put back on the original part, was transferred to the parts department, and they didn't offer such a part.
In this case, why is CO an issue given the WH is in my carport?
Old 02-02-2012, 03:18 PM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 148
Old 02-02-2012, 03:18 PM   #7
MB1
Waterheater Pictures
Photos attached per requests. I'm aware it needs drip pan, drainage to outside, and stronger bracing to meet current code, anything else I'm ignorant of
Per Pictures - Does this waterheater roof vent modification matter?-wh-picts.jpg
Old 02-02-2012, 03:20 PM   #8
Hvac Pro
yuri's Avatar
Rewards Points: 148
OK. It just needs a 4" B vent chimney and extend it 3 feet above the roofline so swirling winds do not affect it and to meet code. Get them to attach it directly to the draft diverter on top of the tank. Looks like they damaged/ruined the one you have and now it needs to be yanked out and redone and supported properly. Cannot just rest on top of the water heater diverter, but you can vent the heater with 4" B vent instead of 3 inch single wall like now. I don't know much about bath fan venting or mobile home codes etc but someone around here in a day or 2 may help. Try posting it in the construction forum too.
snow country ridge vent on 2:12 pitch roof fxtm Roofing/Siding 4 11-01-2011 06:26 PM
very difficult house to vent roof help please marlowe Roofing/Siding 7 09-10-2011 11:57 AM
Roof Heat Vent Leakage vlindell Roofing/Siding 1 08-19-2011 09:58 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 09:57 AM
