Pellet Stove Blowert Motor - HVAC - DIY Chatroom Home Improvement Forum
Old 09-16-2011, 03:37 PM   #1
Pellet stove blowert motor
I have a wood pellet stove and the blower motor is shot. Where can I locate a replacement? Jakel Inc. J238-150-15239
115vac 60hz 3.0A 3,000rpm
Bruce Schmeck is offline   Reply With Quote
Old 02-28-2013, 10:28 PM   #2
I also need one. but the price is pretty high like $240 us
cant find replacement so far
peterber is offline   Reply With Quote
Old 03-01-2013, 04:35 AM   #3
An old Tradesmen
Rewards Points: 6,928
Take it to a motor shop. they may be able to repair it.
Old 03-01-2013, 07:14 AM   #4
was going to try that. just needs bearings. I could do it myself, just afraid to take off the squirrel fans. they are plastic and very tight on the shaft. wonder if they are glues on??
anyone had experience taking them off??
thns
Old 03-01-2013, 08:25 AM   #5
Rewards Points: 13,458
Got a picture?
Is there room on the back side of the fan to slide in two pieces of flat metal so the shaft can be pressed out?
Old 03-01-2013, 03:54 PM   #6
An old Tradesmen
Usually a metal spring clip is all that holds them fast to the shaft.
Old 03-03-2013, 01:09 AM   #7
i got the fans off ok....opened it all up now can't locate the bearings.
the bearing # is NMB 608s almost identical to skate board bearings. but so far no luck on source. the shaft size is 5/16" dia i believe.
tied a supposedly replacement unit. identical fit and size. no go. the fan motor turns very slow. AC supplied to the motor is about 105vac. So the control board has a variable voltage to the motor depending on the heat setting by the looks of things. The difference in the motor specs are: original is 3000 rpm 115vac at 3.0 Amps. Replacement is 2800 rpm 115vac and 1.5 Amp..I can't explain why replacement would turn at very LOW rpm. Cheap motor?? wont turn at reasonable rpm unless full 115/120 vac is applied. runs perfect at full voltage source..GRRRRRR
so looking for bearings for now
Old 03-03-2013, 01:38 AM   #8
Rewards Points: 6,652
$240, you are looking in the wrong places. It is really no different than the fan motor that is used in a fart fan.
http://www.amazon.com/s/ref=nb_sb_no...jakel+fan+j238
Old 03-03-2013, 04:29 AM   #9
An old Tradesmen
Original motor is roughly a 1/3 HP motor, the new motor is roughly a 1/6 HP motor. Its not really compatible.
Old 03-03-2013, 04:03 PM   #10
for ur info: if u can take it apart and change the bearings, look on ebay for 608ZZ. good price. they are skate board bearings 8mm x 7mm x 22mm.
hope that helps..for $10 = new motor
How to replace condensor fan motor? twags HVAC 44 08-27-2015 05:09 PM
Tiling under a pellet stove exiledgator Tiling, ceramics, marble 5 06-14-2011 08:43 AM
Two Wire 24V Thermostat to Digital Thermostat on Pellet Stove jrodtaclet Electrical 4 09-15-2009 05:37 PM
Finishing Basement with Pellet Stove BCav12861 Building & Construction 1 08-15-2008 09:16 PM
Pellet Stove Question webweever General DIY Discussions 4 03-15-2008 02:14 PM
