Old 09-04-2010, 08:09 PM   #1
Pellet Stove
Can I hook up a pellet stove to my existing radiators to heat my home ? We now have a oil burner and would like to remove and add this type of heat.
Inga58 is offline   Reply With Quote
Old 09-04-2010, 08:12 PM   #2
An old Tradesmen
Pellet Stove
It may not be approved as a sole source of heat. Let your current boiler attached. And then also connect your pellet stove.
Old 09-22-2010, 12:17 PM   #3
Pellet Stove
Pellet stoves are intended more as an ancillary/supplemental heat source. So for that reason, and various others, you should keep your existing boiler.
I have seen a home grown 'saddle bag' design over a pellet stove. No idea how well it works.
dac122 is offline   Reply With Quote
circuit board repair for pellet stove mudmusic8 Electrical 4 06-03-2010 11:08 PM
Hooking up a non-equipped pellet stove to a home thermostat bobbyc HVAC 4 09-25-2009 03:24 PM
Two Wire 24V Thermostat to Digital Thermostat on Pellet Stove jrodtaclet Electrical 4 09-15-2009 06:37 PM
Finishing Basement with Pellet Stove BCav12861 Building & Construction 1 08-15-2008 10:16 PM
Pellet Stove Question webweever General Discussion 4 03-15-2008 03:14 PM
