Payne Plus 90 Continuous Blower Operation - HVAC - DIY Chatroom Home Improvement Forum
Old 04-23-2011, 07:44 PM   #1
Payne Plus 90 continuous blower operation
Okay, hoping to get some help!
Replaced blower motor this morning , solder and heat shrink wire connections and went in great.
Turned thermostat to "fan on" and blower ran nice and quiet .
I also was finishing up a Aprilaire humidifier install after the motor instal.
Few hours later went to go test everything and now blower motor does not shut off.
The two relays on the circuit board, they used to click upon initial power up, but now dont...
Removed "G" wire off of circuit board and still have constant fan.
Transformer does put out 24 volts to control board.
Not getting 24 volts where you would wire in the thermostat..."R" and "C".
Will put out heat as it is, havent tried A/C .
Whatddya think ? Circuit board?
Is there an initial 120 volts going to a relay opening the circuit so the fan doesnt run?
Any help is much appreciated!
Jeff
Jeffro69 is offline   Reply With Quote
Old 04-23-2011, 11:04 PM   #2
An old Tradesmen
Rewards Points: 6,072
Sounds like you wired in a short, and the fuse blew.
Old 04-24-2011, 08:13 AM   #3
How would I identify the fuse in the circuit board? Not anything typical to me..
BTW, I do have 24 volts at thermostat screws at bottom of board.
Old 04-24-2011, 09:54 AM   #4
An old Tradesmen
You wouldn't have 24 volts at tstat terminals if the fuse blew.
Old 04-24-2011, 10:23 AM   #5
I did remove the April aire wires and have only the stat and a/c wires on the board. Same issue.
Fan is on all the time....what do i do ?
"If" it was a board....i would sure like to know for sure....dont wanna throw parts aat it.
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 05:39 PM
Payne gas furnace - blower fan running continuously Ed40 HVAC 0 02-05-2011 03:19 PM
proper snow blower operation joshl Landscaping & Lawn Care 6 01-05-2011 03:57 PM
Payne furnace blower won't come on gulley HVAC 7 11-13-2010 09:22 PM
blower fan runs continuous, Baystat 239 tstat chavez36 HVAC 2 10-13-2010 09:44 AM
