"Payne" In My? - HVAC - DIY Chatroom Home Improvement Forum
Old 04-17-2009, 07:55 PM   #1
"Payne" in my?
My furnace 90% payne only fires when i have the sight glass door off the burner assembly any ideas why?
mhoy9 is offline   Reply With Quote
Old 04-17-2009, 08:56 PM   #2
HVAC / Plumbing
It probably needs air........ When you take the door off it has air
kenmac is offline   Reply With Quote
Old 04-17-2009, 08:59 PM   #3
wow thanks clogged vent/pressure switch any extra insight
Old 04-17-2009, 09:04 PM   #4
HVAC / Plumbing
clogged vent.. I don't know how your unit is vented.. I only know it should be PVC.. Does it bring air outside in from the same vent it exhaust through ?? or, Does it have 2 seprate pipes ? If 2 pipes 1 is exhaust 1 is intake
Old 04-17-2009, 09:28 PM   #5
worked fine until recently vented in a concentric
Old 04-17-2009, 09:39 PM   #6
HVAC / Plumbing
Well it's not getting any air for some reason .. Won't burn without air.. Look for obstruction in the intake
Old 04-17-2009, 09:45 PM   #7
HVAC / Plumbing
Does the furnace have a plasitc / rubber plug on the side or top that will allow air to the combustion area ??
