Payne Heater Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 02-13-2012, 10:38 PM   #1
Rewards Points: 16
Have a 15 year old Payne forced air heater, model 373 LAU 048115. So far, to keep it running two years ago I replaced the circuit board and last year the inducer motor. Problem today. Fan comes on, then inducer motor, but igniter will not glow. Receive error code 31. Tried the test mode and everything works fine including the igniter.
Have inspected the complete exhaust vent and there are no obstructions. It seems the vacuum switch is good, but the inducer motor is not pulling any vacuum. The inducer motor and vacuum switch seem to work fine. All the seals look good. Don't know what else to do.
eweneek1 is offline   Reply With Quote
Old 02-13-2012, 10:45 PM   #2
Rewards Points: 582
you say inducer motor is not pulling a vacuum.... check small tube for obstruction that hose connects too clean out with small wire and connect magnaheily gauge and recheck for vacuum..... if your not getting vacuum thats your problem..
Old 02-13-2012, 10:57 PM   #3
Rewards Points: 16
Payne Heater problem
Did as you suggested and checked the tube and there seems to be no blockage. Wire went in a full 2 inches.
Old 02-13-2012, 11:04 PM   #4
Rewards Points: 582
you sure no vacuum..then its has to be wheel inside inducer bad......
Old 02-14-2012, 05:40 AM   #5
An old Tradesmen
Rewards Points: 6,500
Sounds like a drain problem, clean drain lines and trap. Also check exhaust pipe for obstruction.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
ben's plumbing (02-15-2012), dosy777 (02-16-2012)
Old 02-15-2012, 08:21 PM   #6
Rewards Points: 16
Finally got under the house to do some more checking on the vacuum switch. Bypassed the switch, turned heater on, and the vacuum switch did not open. Removed inducer motor, only one year old, and interior and exterior fans both work. Just don't know if they are turning at full speed. Tried to rent a magnaheily gauge to test, but was unable to find one. Filled 3/16 plastic tubing with colored water and started heater. When inducer came on, the water column only moved 1/2". Checked the complete vent system from the inducer out and no obstructions. Don't know what else to check at this point.
Old 02-16-2012, 02:37 AM   #7
how
Rewards Points: 1,102
Some stray questions as I head off to bed.
Make sure the ID assy is properly sealed where it is attached to the furnace. Is there a capaciter on that ID motor?
What is the WC threshold listed on the pressure switch?
When the water in your manometer moved 1/2 inch, was that a 1/2 " total or 1/2 inch on each side?
If your furnace is a high efficiency then the air intake must also be inspected.
how is offline   Reply With Quote
Old 02-16-2012, 04:51 AM   #8
An old Tradesmen
Did you clean out the trap.
The Following User Says Thank You to beenthere For This Useful Post:
Old 02-16-2012, 05:37 PM   #9
Rewards Points: 16
Payne Heater Problems
The ID assembly, model is properly sealed where it is attached to the furnace.
There is no capaciter on the ID motor.
Can not find the WC threshold listed on the pressure switch. The only numbers are FS6675-1320 and HK06WC076.
The water in the manometer moved 1/2 inch on each side.
The furnace is mount horizontal under the house and I do not see a drain or trap.
The furnace is a fan assist draft 80+ furnace about 15 years old.
Old 02-16-2012, 08:35 PM   #10
how
A 1/2 " drop on each side of the tube is a 1" WC measurement which is not that unusual for an ID assy.
Did you look on the back side of the switch for a WC listing?
Old 02-16-2012, 11:41 PM   #11
Rewards Points: 16
Can not find the WC rating on the pressure switch label. The only other numbers on the switch are 015917 / 2792.
Old 02-17-2012, 12:35 AM   #12
how
I guess Payne is living up to it's name again. Some manufacturers are secretive about divulging info that might result in diagnosis as opposed to part replacements.
All I found was a listing saying that the current part number for that pressure switch is HK06WC090 but without any helpful details like WC info.
Old 02-17-2012, 09:34 AM   #13
Closes at 1/8" WC ....opens at .28" WC.
hvac5646 is offline   Reply With Quote
The Following User Says Thank You to hvac5646 For This Useful Post:
ben's plumbing (02-17-2012)
Old 02-17-2012, 12:08 PM   #14
how
What Hvac5646's WC info would normally mean (considering your 1" manometer measurement of the ID assy) is to change the pressure switch.
BUT....
I am a little confused however why Payne would pair a pressure switch with an ID assy with that level of pressure disparity.
If Hvac5646 's info is correct, then it makes me wonder if your ID WC measurement is actually stronger than it should be.
It makes me wonder about the ID that you changed last year?
The Following User Says Thank You to how For This Useful Post:
Old 02-17-2012, 01:14 PM   #15
BUT....
right from the book and verified by the wholesaler
how (02-17-2012)
Whirlpool Energy Saver Water Heater Problem Thurman Electrical 47 02-12-2017 09:24 PM
Paint stripper problem on baseboard heater cover bingwah Painting 4 08-23-2009 07:34 PM
Heater starts...then stops. Help! beagan HVAC 3 12-04-2008 03:40 AM
problem with water heater Charles Sexton Plumbing 2 10-12-2008 09:55 AM
Electric Water Heater Problem mw2727 Plumbing 4 08-21-2008 02:51 PM
