Old 11-03-2009, 07:08 PM   #1
Default payne heat pump with older bryant fan coil
can i use a Payne PH13NR030 heatpump with my existing Bryant FB4A 30 indoor fan coil/air handler ?
i orginally had a Bryant 693CNX030 heatpump with a SEER 10.10 and the Payne heat pump is a 13.0.
any problem in using this combination? They are both 2 1/2 ton.
any help would be appreciated. thankyou.
macmichael is offline   Reply With Quote
Old 11-03-2009, 09:18 PM   #2
An old Tradesmen
It list it as a match no problem.
If they don't. you will probably have lots of trouble. The refrigerant charge will never be right if its not a match.
Old 11-04-2009, 08:34 AM   #3
A 10 seer coil is not a match for a 13 seer heat pump. Replace both componets at the same time.
Old 11-04-2009, 01:32 PM   #4
For less than ideal performance it may work. But the right way is to get a matching coil, and not be penny wise, but pound foolish. It could easily cost more in labor to get the thing balanced than to just replace with an approved match.
Why are you having to consider this scenario?
dac122 is offline   Reply With Quote
Old 11-04-2009, 02:14 PM   #5
thankyou for the responses to this thread. the reason i inquired about this is i recently purchased a Payne PH13NR30 thinking that a 2 1/2 ton outside unit would be compatible with my inside unit and all i would have to have done ......is swap out the heat pumps. Does anyone know if i can just replace the fan coil or must the whole air handler/fan coil be replaced? thankyou
Old 11-04-2009, 05:00 PM   #6
An old Tradesmen
I don't know if a matching Payne 13 SEER indoor coil is available.
You may be able to get a Superior, Mortex, or ADP coil.
But may have to go through a contractor to get it.
Old 11-04-2009, 08:23 PM   #7
Heat pumps are more critical in regards to matching equipment. I would contact an HVAC contractor to locate you a matching unit. It's not a good idea to hook up equipment with different seer ratings. It can void factory warranties,especially in regards to compressors.
mikef54 is offline   Reply With Quote
More On This Topic
Nothing can ruin your summer or winter like finding you have no heat or air conditioning because your heat pump is malfunctioning. If you have to buy a new heat pump, an uncomfortable season can turn into an uncomfortable year. However, heat pumps are... Read More »
Solar power has come a long way in the last few decades. What once seemed like an ecological pipe dream has become a viable means of producing electricity. To save money on your electric bill and preserve precious environmental resources, you should... Read More »
Attending a World Wrestling Entertainment (WWE) live event is the ultimate way to experience everything that is professional wrestling. The exciting, over-the-top performances have kept dedicated fans screaming for more and nowhere is that more evident... Read More »
Hi this is Jon on behalf of Expert Village in this video clip we will be installing our ceiling fan. Sine this room is going to be for a girl, we've purchased this ceiling fan which is a more feminine. Now our ceiling fan is a 44" fan, now you don't want... Read More »
How Theremin Coils are Made
How Theremin Coils are Made by Expert Village
On behalf of ExpertVillage.com my name is Mark. Just how did I make the coils that are in the Theremins? Well the original ones I made by hand. I would wrap the wire one turn at a time and it was so easy to not get the tension right, originally I used a... Read More »
Heat pump problem, indoor fan blows in heat but not A/C or "on" lngroller HVAC 2 06-03-2009 09:55 AM
Heat Pump set back GEAF HVAC 6 01-26-2009 09:49 AM
Heat pump ice up signpainter HVAC 8 12-08-2008 04:46 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 01:49 PM
Heat Pump Troubleshooting (Advice/Help) Drawknife HVAC 5 02-01-2008 04:41 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
