Payne Furnace Problem - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-03-2009, 01:57 PM   #16
An old Tradesmen
Rewards Points: 6,112
And fuel was cheap when they installed them.
No one cared if an oil burner used 2000 gallons to heat a 1600 sq ft home when it was $0.05 a gallon.
Old 05-03-2009, 07:00 PM   #17
HvacWiz's Avatar
Rewards Points: 252
Being from a area that has had numerous floods over the last several years ,you are more than likely going to have to replace your circuit board and possibly the blower motor as well.
HvacWiz is offline   Reply With Quote
Old 05-03-2009, 10:36 PM   #18
Originally Posted by qbert View Post
Test to make sure tstat is closed and calling for heat, check all wiring loose connections test limits and sensors (aux limits) if all is good then i would say bad circuit board. I would test all first to be sure unless you like to spend money on a guess
Gee, sitting in 8' water and you tell him to check the stat and limits...where do they come from?
hvaclover is offline   Reply With Quote
Old 05-04-2009, 12:01 AM   #19
as seen on tv
Rewards Points: 150
Where i come from you make sure of a problem although it may be obvious we start from the top and work are way down eliminating the problem by testing and process of elimination. jumping in with out testing is a sure call back generator. what furnace has a control that sits on the floor of a blower cabinet?
qbert is offline   Reply With Quote
Old 05-04-2009, 12:32 AM   #20
Actually the control board is quite near the bottom of this furnace. It looks like the board might have been partially immersed from the looks of the cover on the board. I went over this afternoon to try and retrieve the codes blinking from the board. All in vain, everything seems dead. Since it tried to start yesterday, at least I know that the blower motor is functional. Only logical conclusion that I can see is a bad control board. Next step is to remove the control board sometime this week to see if I can salvage it, maybe some obvious corrosion or a short on the circuit board itself, I also read there is supposed to be a fuse on the control board? If it still doesn't work guess I'll need to bite-the-bullet and buy a new control board. Looks like the HK42FZ011 is available for about $200. I'd rather take a shotgun to the Payne Than put the money into it, but even though it would be most satisfying, it wouldn't solve the problem. Guess I just can't sell the house without a working furnace in it. Course the good thing is that it is still quite cold at night up here in Michigan and not having a working furnace will encourage my son to speed up moving out of the house so I can try and sell it! Good and bad in everything I guess. Hey Guys, I really appreciate all the advise given and I will let you'all know how it turns out.
Laughingchi is offline   Reply With Quote
Old 05-04-2009, 07:13 PM   #21
I'll bring the shells and load for you.
But you gotta get in the heart or it won't die
Old 05-04-2009, 07:26 PM   #22
Hvac Pro
yuri's Avatar
Rewards Points: 1,122
One of my customers cranks the heat UP high in his house to try and sweat his deadbeat son and friends out. And having no food in the fridge helps. LOL
Old 05-16-2009, 05:31 PM   #23
Payne Pain
Hi All,
I finally got back to check the control board in the furnace. After coding all the wires with multi-colored electrical tape and making a diagram of where everything plugs in, I think I should be able to put a replacement board back in. The board had about 1 1/2 to 2 inches of corrosion. There was a definite water line on the board. Pure corrosion! In fact, one of the resistors corroded right of the board and was laying loose in the control board cover, I didn't think it should rattle, even if it's a Payne...LoL! Unfortunately the "bug" also got wet, so I'm not even going to waste the effort trying to clean off the board.
I do want to thank everyone for their advice, it's been appreciated!
Old 05-24-2015, 11:19 AM   #24
Rewards Points: 12
Hi all. I recently inherited a house and storms last week flooded the basement with 8" of groundwater. Augered out the drain & water receeded but now having problems with the furnace. It's a Payne 80 Plus, the inside label says the model is a 395CAV024070. I can find nothing on it. Online schematics show a resemblance to Bryant PG8 furnace. My question is this: When I try to start the furnace the blower starts in short bursts, a clicking noise (sounds like a relay) is coming from what I believe is the control board and a red LED is blinking on & off on the side of the control board. (it does not get to the part of the startup cycle where the draft inducer turns on or the gas flows, just the main blower trying to start) Presumably the lower 8" of the furnace was immersed in the groundwater overnight. Any insight/suggestions would be appreciated. Replacing the furnace is not a viable option as funds are limited. Lookingh at possible layoff. Thanks in advance.
I have one with that number, and is a Bryant.
partwerks is offline   Reply With Quote
Old 05-24-2015, 11:34 AM   #25
Rewards Points: 196
Any blinking from that board if a fault code.Steady red is a normal condition.If that board got wet in any way, it is toast.If you let the blower dry out completely it might be ok.The typical problem with the board is a burn't trace at the blower relay, but that is a board that hasn't been in water, plus everything would work until it was time for the blower to come on.
HVACTECH96 is offline   Reply With Quote
Old 05-24-2015, 04:21 PM   #26
how
Rewards Points: 1,070
Have you checked how dead that posting is? (2009?)
how is offline   Reply With Quote
Old 05-24-2015, 04:59 PM   #27
Rewards Points: 1,989
At one time Bryant , Payne , Daylight , BPD and maybe Carrier were pretty much all the same company .
God bless
Wyr
WyrTwister is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 08:01 PM
Miller G5RA furnace flame sensor problem mpit52 HVAC 3 01-16-2009 11:30 AM
Furnace Problem Juanacuna24 HVAC 1 12-28-2008 10:13 PM
Problem with Payne ultra 90 Mark H HVAC 19 12-31-2007 09:25 PM
another question for a miller furnace problem jb9270 HVAC 1 02-05-2007 03:04 PM
