Payne Furnace Prob - HVAC - DIY Chatroom Home Improvement Forum
Old 01-31-2011, 06:06 PM   #1
payne furnace prob
after turning on the heat the furnace combustion box overheats causing manual limit switch to go off . i have the heat set to 66 degree however it only gets to 58 degrees. the furnace exhaust gets a natural gas smell outside. the furnace gives code 33, and blower motor runs until i reset furnace it was installed 97
i replaced cleaned
cleaned intake and exhaust pipe
thermostat
air filter
replaced burned out draft inducer
last yr replaced flame sensor and flame ign.
payne furnace model #490aav036060
drisco is offline   Reply With Quote
Old 01-31-2011, 06:16 PM   #2
HVAC / Plumbing
not getting enough air flow across the HX .dirty coil. closed off vents , not enough return air
kenmac is offline   Reply With Quote
Old 01-31-2011, 06:22 PM   #3
i cleaned the coil
Old 01-31-2011, 06:23 PM   #4
all vents open air comes out
Old 01-31-2011, 06:26 PM   #5
HVAC / Plumbing
Is this 1 of the small limits that you reset by pushing a small button. If so it's a roll out limit & you need to have the H X or vent system checked
Old 01-31-2011, 06:31 PM   #6
yes it is one of the small ones u push in did and over heated ? could u be limit switch on fire wall
Old 01-31-2011, 06:33 PM   #7
HVAC / Plumbing
Can't make out what this means. You need to have a PRO check your unit
Old 01-31-2011, 06:55 PM   #8
. [IMG]file:///C:/DOCUME%7E1/owner/LOCALS%7E1/Temp/moz-screenshot.png[/IMG][IMG]file:///C:/DOCUME%7E1/owner/LOCALS%7E1/Temp/moz-screenshot-1.png[/IMG]one of my friends thought that the Heat exchangers, are sooted and or limit switch on fire wall behind draft inducer is at falt
Old 01-31-2011, 08:17 PM   #9
HvacWiz's Avatar
Rewards Points: 252
Your secondary heat exchanger is plugged up.
HvacWiz is offline   Reply With Quote
Payne furnace problem Laughingchi HVAC 26 05-24-2015 03:59 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
