Payne Furnace Needs New Fan - HVAC - DIY Chatroom Home Improvement Forum
Old 09-06-2010, 09:17 PM   #1
Payne furnace needs new fan
Payne furnace needs new fan-007.jpgHi, I'm trying to remove the wheel from my Payne furnace, it does not spin. I removed 3 hex screws (2 on top, 1 on bottom) and the piece with the wheel will not come off. I do not want to damage anything by forcing it off. Am I missing a screw somewhere? The man from the Gas Company came out and I thought he pointed to the screw on the wheel when he told me the reason my heater wasn't working, but it doesn't seem likely to me that the screw would be what's holding it on. Plus, I did try to remove that screw, but it's not a regular hex screw, it only has one flat side and I couldn't find anything that would take it off.
Model #480BAV048091APJA
Serial #0397A05488
Any help would be greatly appreciated.
Also, I read in another thread that the flame sensor needs to be cleaned once a year. If somebody would be so kind to let me know where and how to do it, I would be quite grateful.
NancyG is offline   Reply With Quote
Old 09-06-2010, 09:25 PM   #2
The whole assembly comes off. The wheel is connected to a motor shaft.
hvaclover is offline   Reply With Quote
Old 09-06-2010, 10:04 PM   #3
Thank you, Hvaclover. What I'm wondering is, after taking out the 3 hex screws, are there any other screws? It is stuck and I'm afraid to force it off.
Old 09-06-2010, 10:05 PM   #4
.....Or, should I just force it off?
Old 09-07-2010, 02:25 AM   #5
Don't force it.
there are hex head screws around the motor housing. Probably 5/16" nut driver size.
Payne furnace problem Laughingchi HVAC 26 05-24-2015 03:59 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
payne furnace inducer motor minime_moomey HVAC 13 02-20-2010 12:52 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
