Payne Furnace -- Error Code 12 - HVAC - DIY Chatroom Home Improvement Forum
Old 03-05-2011, 09:22 PM   #1
Payne furnace -- Error Code 12
I have a Payne furnace that sometimes flashes an error code 12. A tech replaced the circuit board earlier this week and it seemed to be working fine.
It's now flashing the error code 12. After the furnace turns off, the red light doesn't flash. Only flashes when it's trying to run properly.
orcaboy is offline   Reply With Quote
Old 03-05-2011, 09:36 PM   #2
how
Rewards Points: 1,070
Check your manual or the index info (sometimes glued on inside of the furnace door) or google for what that 12 code means. Some codes just say that you've got power and everything is OK.
Do you have any other indication of a problem?
how is offline   Reply With Quote
Old 03-05-2011, 09:41 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
Fault Code 12 indicates a power interruption on the furnace powered up during a call for heat. If this code is present, verify that the blower runs for ninety seconds before the furnace starts a normal heating cycle.
You sure it is not a 21 instead?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 03-05-2011, 10:02 PM   #4
Based on the description of how to read the error code, it's a 12.
The furnace kicks on, runs and I can see the orange glow. The burners then kick on and I can see the blue flame. Just before the fan blower starts to run, the burners turn off and the 12 code flashes until the unit cycles off. Once it's off, the light remains red and does not blink.
It doesn't do this all the time.
Old 03-05-2011, 10:04 PM   #5
Also -- the furnace is keeping the temp in the house steady, even when I've been getting the error code. The air coming out of the vents seems a little cool, but the house isn't cold.
Old 03-05-2011, 10:14 PM   #6
AKA HVACTECHFW
Code 12 only comes on when the furnace is powered off and the stat is calling for heat and the furnace was powered on.
IT IS WHAT IT IS
Old 03-06-2011, 04:57 AM   #7
An old Tradesmen
Rewards Points: 6,140
Sounds like a loose line voltage connection somewhere.
Old 03-06-2011, 05:41 AM   #8
Thanks ... looks like I'll be calling for another service call.
Meantime, any suggestions on things I could check myself?
Old 03-06-2011, 05:43 AM   #9
An old Tradesmen
Line voltage wire connects inside and outside of the furnace.
Old 03-06-2011, 05:46 AM   #10
I'll check things out and will post results.
Anu chance I could have a bad thermostat?
Old 03-06-2011, 05:52 AM   #11
An old Tradesmen
A low voltage thermostat is not going to cause a loss of line voltage power.
Old 03-06-2011, 05:54 AM   #12
That's what I figured, but was hoping for a quick, easy and inexpensive fix.
Old 03-10-2011, 08:27 AM   #13
Still working through the issue. Tech replaced a relay, checked all electrical connections, ground, etc.
Unit still throws a 12 code at times, but still very hit-and-miss.
Was able to trigger the 12 code by lowering thermostat temp while burners are fired but before the fan kicks on.
Old 03-10-2011, 05:39 PM   #14
An old Tradesmen
That shouldn't give that error. Loose connection somewhere, or a cold solder joint on the board.
Old 03-10-2011, 07:37 PM   #15
how
I'm doubtfull... "beenthere"
I don't think that when a board is flashing 12 and is replaced by a new board that also starts flashing 12, that a diagnosis of 2 seperate identical cold solder faults is likely. Are you suggesting a 3rd board?
I'd keep looking for that loose connection everywhere.
Do your house lights flicker occaisionally? I've had hairy diagnostic issues from both a loose neutral at the pole and from another with a loose house ground.
This job used to be simple!
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
payne furnace prob drisco HVAC 8 01-31-2011 09:17 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 07:42 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
