Old 11-11-2010, 04:00 PM   #1
Payne furnace blower won't come on
Payne 376C downflow model furnace... Units heats in response to thermostat commands but blower won't come on. I live in California and haven't tried to turn on the furnace since last winter. Door is in place so switch is depressed as it should be. Can an idle blower motor go bad just like that? Any tests I can do? MANY thanks.
gulley is offline   Reply With Quote
Old 11-11-2010, 04:40 PM   #2
HVAC / Plumbing
Have you checked capacitor ?. If it's good. Check the terminals on the board where fan connects. Should be voltage on the terminals on a call for heat / cool
kenmac is offline   Reply With Quote
Old 11-13-2010, 02:25 PM   #3
Power (120v) is flowing to the compartment where the thermostat wires connect (and where I presume there is a circuit board), but nothing comes out of there.
Old 11-13-2010, 02:33 PM   #4
An old Tradesmen
Need to check it with the blower safety switch depressed, and the board either calling for the blower to run because of the heat call. Or the stat set to fan on.
Old 11-13-2010, 08:29 PM   #5
Yes, switch is depressed and thermostat is set to 'fan on.' Nothing.
Old 11-13-2010, 08:42 PM   #6
An old Tradesmen
Did you jump R to W, or R to G and when you did this.
Old 11-13-2010, 09:13 PM   #7
I don't understand. Current flows to circuit board compartment through wires with plastic snap-in connectors. I stuck a continuity tester in the connectors and there was definitely power IN. None OUT.
Old 11-13-2010, 09:22 PM   #8
An old Tradesmen
How much power in?
Need to use a voltage tester.
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Blower problem on American Standard Freedom 90 furnace ekimmo HVAC 8 08-27-2011 10:13 PM
Trane Furnace Blower Running Nearly Continuously stephensandlin HVAC 3 01-03-2010 02:21 AM
Bryant Gas Furnace - blower sarts and stops montepix HVAC 7 12-24-2009 05:11 PM
Bryant Furnace Blower Running Constantly GhostBuster HVAC 15 11-30-2008 10:08 PM
