-   -   Payne furnace blower won't come on (http://www.diychatroom.com/f17/payne-furnace-blower-wont-come-86470/)
gulley 11-11-2010 04:00 PM
Payne 376C downflow model furnace... Units heats in response to thermostat commands but blower won't come on. I live in California and haven't tried to turn on the furnace since last winter. Door is in place so switch is depressed as it should be. Can an idle blower motor go bad just like that? Any tests I can do? MANY thanks.
kenmac 11-11-2010 04:40 PM
Have you checked capacitor ?. If it's good. Check the terminals on the board where fan connects. Should be voltage on the terminals on a call for heat / cool
gulley 11-13-2010 02:25 PM
Power (120v) is flowing to the compartment where the thermostat wires connect (and where I presume there is a circuit board), but nothing comes out of there.
beenthere 11-13-2010 02:33 PM
Need to check it with the blower safety switch depressed, and the board either calling for the blower to run because of the heat call. Or the stat set to fan on.
gulley 11-13-2010 08:29 PM
Yes, switch is depressed and thermostat is set to 'fan on.' Nothing.
beenthere 11-13-2010 08:42 PM
Did you jump R to W, or R to G and when you did this.
gulley 11-13-2010 09:13 PM
I don't understand. Current flows to circuit board compartment through wires with plastic snap-in connectors. I stuck a continuity tester in the connectors and there was definitely power IN. None OUT.
beenthere 11-13-2010 09:22 PM
How much power in?
Need to use a voltage tester.
