Old 12-06-2008, 12:34 PM   #16
Payne 480BAV:Error 31
Check for continuity acrossed the thermal fuse you show in the pic. Also check for continuity acrossed the vent safety switch (the round thing) and check the high limit too. Thats the part that the thermal fuse is connected to.
SKIP4661 is offline   Reply With Quote
Old 12-06-2008, 02:01 PM   #17
Talking
WOOOOO HOOOOO!!!!!! check out those blue flames of victory boys!!!!! Nothing like knowing nothing about furnaces to a fixed one after a two week battle....leaves ya all warm and fuzzy inside knowing I was only a blink from dropping $3k on a new one.
The round thing (draft safty switch) needed to be reset. Sure didn't look like switch/fuse/resettable thing.
Payne 480BAV:Error 31-flame.jpg
thealexdexter is offline   Reply With Quote
Old 12-06-2008, 02:05 PM   #18
The million dollar question though...
Why did it trip in the first place? I still think that damper is way too stiff. Now that it is working I see the damper is not open or open so little that I can't tell. There seems to be a lot of air flow from the garage into the furnace. I would expect most of the air to come from the return vent and the fresh air vent...but maybe it because the cabinet doors are off that it can't get enough pressure to open the damper?
This is a pic of the damper. There is a flex line coming from the outside of my house under the crawl space and into this damper which is located at the base of my furnace under the filter. If the camera were zoomed out and panned up about 6" you'd see the control board. (upflow furnace)
I may go back and put the old control board back in a see if it was really bad.
Payne 480BAV:Error 31-damper.jpg
Old 12-06-2008, 02:07 PM   #19
An old Tradesmen
Your welcome.
Looks like a fresh air intake for the house.
Not a combustion air intake.
Old 12-06-2008, 02:10 PM   #20
Thanks for your help everyone!!!!!!
Do you think it's ok that it is that stiff on the fresh air intake damper, beenthere?
Old 12-06-2008, 02:17 PM   #21
An old Tradesmen
Is it locked in that position by a wing nut?
Old 12-06-2008, 02:34 PM   #22
Hvac Pro
I would keep the old board for a spare and leave well enough alone. Those connectors are not meant to be taken apart multiple times. If you have a open fireplace/powerful JennAir range fan or other exhausting devices you may have had a downdraft down the chimney and that caused the spill switch to open.
Old 12-06-2008, 02:43 PM   #23
I don't see any wing nuts on the damper on the furnace side....I can't see the other side without major diassembly.
I don't have any other gas appliances or powerful vents other than a very cheap decorative fireplace that is not on any of the same air intakes or exhaust vents. The gas water heater shares the same exhaust vent.
I already put the old board back in..everything is fine! I'll keep the new one as a spare for a few weeks. if all is well I'll put it back on ebay.
I paid over $200 for a tech to tell me the board was bad, along with two other things and it was only a stupid resetable switch. Do you think I should call up the tech and ask for a partial refund of oh..$150 or so? Seems like he should have at lease checked resetable fuses/switches before telling me my furnace is so trashed I'd be better off buying a new one!
Old 12-06-2008, 10:37 PM   #24
An old Tradesmen
Its ok to call a company and let them know their diagnostics were incorrect.
And to ask about a refund.
Tags
480bav, draft safety switch, fresh air damper, inducer motor, pressure switch
Payne Vs Goodman darman16 HVAC 34 11-03-2008 10:44 AM
Problem with Payne ultra 90 Mark H HVAC 19 12-31-2007 09:25 PM
Payne Furnaces mick6311 HVAC 1 06-26-2007 10:10 PM
Humid - Switched Trane xl1200 AC for a Payne HP - now very Humid dagrappler HVAC 1 06-11-2007 01:16 PM
new 3 ton hvac Payne units. No cool air comes out when fan, compressor,thermostat run runbikeengr HVAC 10 04-10-2007 06:59 PM
