Payne 376C Stopped Working - HVAC - DIY Chatroom Home Improvement Forum
Old 05-15-2011, 07:34 PM   #1
Payne 376C Stopped working
I have a Payne 376c Furnace that seems to have just stopped working. The inducer motor turns on and eventually the blower motor turns on but the HSI never heats up so of course the burners never light. Is there anything that this specifically indicates??
BTW, the furnace uses a 310305-201 controller so it has no diagnostic dsplays. Also, shorting together the two self test pins didn't seem to do anything.
dhigginx is offline   Reply With Quote
Old 05-15-2011, 08:26 PM   #2
Voltage to the HSI ?
Old 05-15-2011, 08:45 PM   #3
I just checked about 2.5Vac
Old 05-15-2011, 08:52 PM   #4
Bad control board then.
Old 05-15-2011, 09:33 PM   #5
I so $229.87 hoped that wasn't the problem!!!
Old 05-31-2011, 07:19 PM   #6
I pulled the controller board out in anticipation of replacing it and I thought that just for grins I would check the output of the 24V transformer. To my surprise it read 6.6v. I have a feeling that this may be the only problem, should I replace it first?
EDIT: I actually had a meter battery problem. When I replaced the battery I found that the transformer was putting out at least 24v (28.? actually) I then double checked the voltage to the HSI and came up with 6.7V.
Does this still sound like the Control Board is bad?
Tags
burners , controller , igniter
VERY EERIE! Remote garge door openers and both car remotes stopped working! proofer Automotive Repairs 16 12-03-2016 08:31 AM
Circuit stopped working, breaker did not trip nr5667 Electrical 7 07-08-2012 03:31 AM
Receptacle stopped working lovetobuild Electrical 3 02-11-2011 10:05 AM
Garage door keypad stopped working bklyn1028 General DIY Discussions 7 02-17-2010 07:32 AM
Receptacles/Sockets stopped working BuffaloWinters Electrical 6 01-31-2010 09:25 PM
