Partially Finished Basement HVAC - HVAC - DIY Chatroom Home Improvement Forum
Old 01-24-2011, 01:15 PM   #1
l22
Partially finished Basement HVAC
I have a partially finished basement (400 sf Finished/300 sf unfinished). Currently there is just one vent off of the plenum in the unfinished side. I was thinking of extending and splitting that single vent between both sides and adding a cold air return to the finished side. The basement is entirely below grade, always cool in summer, but a little too cool in the winter. Is just one return and vent enough?
l22 is offline   Reply With Quote
Old 01-24-2011, 01:22 PM   #2
Experienced
Jackofall1's Avatar
I would add a vent for each side, from the ducting, not from the plenum and add a return air for the finished side. Make sure you have dampers in the runs so you can isolate in the summer.
Add return air to keep things balanced.
Good Luck
Mark
Vapor barrier requirement for finished basement JTK Building & Construction 13 02-05-2011 05:30 PM
Cold Room in Finished Basement Creekbender Building & Construction 4 01-31-2010 09:54 AM
Basement Fireblocking within HVAC Soffit ssmith147 Building & Construction 3 12-31-2009 07:36 AM
HVAC for finishing basement ossrocks HVAC 3 12-09-2009 01:15 PM
Need HVAC solution for basement - 3 zone? or ductless units? skylake HVAC 2 10-06-2009 08:42 PM
