Old 11-24-2006, 09:04 AM   #1
Part-time heat
Looking for advice on the problem with my furnace.
I have an 11yr old Comfortmaker RPJ II furnace and am having intermittent heat problems. The furnace is unable to reach the desired temp without repeated manual calls for heat. On the first cycle, it runs properly, on a 2nd cycle the ignitor glows but the gas valve will not open so I only get room temp air blowing. On the 3rd cycle attempt the ignitor will not glow and valve will not open.
Wondering if anyone knows if this is a sensor issue or a control board issue?
Iceberg is offline   Reply With Quote
Old 11-24-2006, 10:26 AM   #2
Part-time heat
It could be many things, those units are very tempramental, and better left to a pro.
acefurnacefixer is offline   Reply With Quote
Old 11-24-2006, 12:36 PM   #3
Thoroughbred Mopar Man
Part-time heat
Hi Iceberg
If your furnaces gas valve says Honeywell Smart Valve on it. You will have to replace the gas valve, you have no choice. If it does not have the smart valve, if you give me a little more to work with I will help you nail the problem.
Good luck
Rusty
#CARRIERMAN is offline   Reply With Quote
Inducer Part Needed: Please Help! BDPNA HVAC 55 12-08-2010 09:48 AM
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 11:22 PM
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 01:27 PM
so your a part time carpenter? bgd73 Off Topic 6 07-31-2007 09:28 AM
Steam heat vs Hot water heat helpless handyman HVAC 5 10-03-2006 09:57 PM
