-   -   Part-time heat (http://www.diychatroom.com/f17/part-time-heat-4982/)
Iceberg 11-24-2006 09:04 AM
Part-time heat
Looking for advice on the problem with my furnace.
I have an 11yr old Comfortmaker RPJ II furnace and am having intermittent heat problems. The furnace is unable to reach the desired temp without repeated manual calls for heat. On the first cycle, it runs properly, on a 2nd cycle the ignitor glows but the gas valve will not open so I only get room temp air blowing. On the 3rd cycle attempt the ignitor will not glow and valve will not open.
Wondering if anyone knows if this is a sensor issue or a control board issue?
acefurnacefixer 11-24-2006 10:26 AM
It could be many things, those units are very tempramental, and better left to a pro.
#CARRIERMAN 11-24-2006 12:36 PM
Hi Iceberg
If your furnaces gas valve says Honeywell Smart Valve on it. You will have to replace the gas valve, you have no choice. If it does not have the smart valve, if you give me a little more to work with I will help you nail the problem.
Good luck
Rusty
