Is This Part Of The Expansion Valve - HVAC - DIY Chatroom Home Improvement Forum
Old 09-09-2012, 05:24 PM   #1
Rewards Points: 66
Is this part of the Expansion Valve
SAw a very small copper tube coming out of the coil and going down to the suction line. Went to investigate as any homeowner should not do and discovered this bulb type item:
digitalplumber is offline   Reply With Quote
Old 09-09-2012, 05:26 PM   #2
HOTDAWG
Looks like your txv
Affordable Comfort, assisting with furnaces Barrie and surrounding area, as well as offering 24 hour furnace repair
Acomfort is offline   Reply With Quote
The Following User Says Thank You to Acomfort For This Useful Post:
digitalplumber (09-09-2012)
Old 09-09-2012, 06:03 PM   #3
hi yes thats the tx valve sensing bulb and its recommened that it is insulated , so i would wrap it with some armaflex wrap or a foam tape wrap of some sorts
hvac dude is offline   Reply With Quote
The Following User Says Thank You to hvac dude For This Useful Post:
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Mixer valve to transfer valve installation CarlV Plumbing 0 09-13-2011 11:28 AM
Help w/ mixing valve (I think) ink HVAC 15 02-28-2010 10:01 PM
How to install thermostatic reactive valve and repack supply valve Leah Frances How To Guides 1 06-10-2009 10:49 AM
Expansion Valve Stuck Closed JustinD HVAC 3 08-31-2007 04:59 PM
