Painting A Rusted Gas Line - HVAC - DIY Chatroom Home Improvement Forum
Old 01-22-2013, 08:43 PM   #1
painting a rusted gas line
Hi -
A quick (hopefully) question concerning a gas furnace. I recently discovered a very slow water line drip that was above my furnace. It has since been fixed, but it seems as though a very minscule amount of water was dripping into the guts of my furnace. The good news is that I believe that none of the electronics were affected. The bad news is that I am noticing some rusting on the curve of the gas line just before the control valve.
My question is this: should I use a special paint (or something else) to help prevent any further corrosion of this pipe? I don't detect any gas at this point, but I would like to play it safe.
Any advice you might provide is much appreciated.
Thanks!
sobro is offline   Reply With Quote
Old 01-22-2013, 09:15 PM   #2
Rewards Points: 12,882
The thick steel pipe and at some point even the moisture in the air can give you some surface rust.
I would not paint them, reason being is it will stink up the whole house when that heater turns on when it burns the fumes from the paint.
This summer when your bored and it's not running and the pilots off go ahead and paint it yellow to ID it as a gas line.
jagans (01-22-2013)
Old 01-22-2013, 10:29 PM   #3
Sounds good - thanks!
Old water supply line a_lost_shadow Plumbing 7 04-20-2012 12:12 AM
Condensate Drain Line Mystery (pan full but no primary clog?) CarrieLP HVAC 21 04-05-2012 12:07 AM
tapping water line for new line KarlJay Plumbing 5 07-28-2010 10:30 AM
New ICe maker line causes ice to taste like rubber speedster1 Plumbing 5 06-27-2010 09:09 AM
electric line and gas line couch potatoe Electrical 17 09-30-2008 11:43 PM
