Packaged Heat Pump Question - HVAC - DIY Chatroom Home Improvement Forum
Old 02-06-2012, 06:13 PM   #1
Ron Paul 2012
In our building we have a packaged heat pump unit in the wall and it only seems to work on heat when we set the thermostat to a much higher temperature.
We could set it on mode cool at 74 and it would be fine, but if someone cares to have it warmer and bumps up the stat to 79. The heat never seems to kick in.
It is a relatively new (2 years) unit and is this just common operation or could there be something else going on?
HandymanCA is offline   Reply With Quote
Old 02-06-2012, 06:47 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
I would contact the company that installed it. With only 2 years old it should have warranty.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
The Following User Says Thank You to Plumber101 For This Useful Post:
HandymanCA (02-07-2012)
Old 02-07-2012, 12:13 AM   #3
Ron Paul 2012
Thanks for the heads up.
Help deterimine age of Armstrong packaged heat pump, model # PWC18E7 Ser # A20626DMA Mark Gammell HVAC 2 04-16-2011 10:20 PM
Hello I have a heat pump question? pennie100 HVAC 7 01-11-2010 11:08 AM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
Heat Pump set back GEAF HVAC 6 01-26-2009 07:49 AM
Easy Heat Pump Question brutis HVAC 6 11-03-2008 10:06 AM
