Package Air Conditioner Fix-up - HVAC - DIY Chatroom Home Improvement Forum
Old 06-27-2012, 10:57 PM   #1
Rewards Points: 1,521
Package air conditioner fix-up
We have an all-in-one, or package, air conditioner. Much of the air handling section is insulated with insulation board of indeterminate type that is either missing or damaged. Years ago I went to the local AC parts distributor and asked for something to repair it but they wanted 130 dollars for a 4x8 sheet of whatever they were selling me so I just used some plastic wrapped wall-type insulation to try to patch it up.
I need to clean that unit up and get it back to it's best performance (it will be over 100 for the next 10 days) so I guess it is time to take it apart, clean and straighten fins, deep clean the unit, and replace the insulation, as well as some duct work that needs fixing up. Probably the smart thing would be a new AC but I'd rather try to get another year or two out of this one since we're also building a new home.
So what type of insulation is it that goes in there that would be 130 dollars a sheet? Should it be rockwool? I can't find faced rockwool in 1 inch thickness. Is it something else special? Besides what comes from the factory, what other options are reliable, safe, and healthy for insulating air conditioning components like that?
Thanks,
Dale
dalepres is offline   Reply With Quote
Old 06-27-2012, 11:36 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Duct board.
Fiberglass regulated spray adhesive.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
dalepres (06-28-2012)
How I can repair My new air conditioner that drip water into my room? skolo HVAC 7 07-15-2011 11:12 AM
Armstrong package air conditioner furnace issue cptkrk HVAC 2 12-14-2010 08:28 AM
New Air Conditioner trips breaker Cano Electrical 4 07-11-2010 10:29 AM
Heat pump vs. Furnace and Air Conditioner heating&cooling HVAC 11 06-16-2010 06:07 PM
furnace and air conditioning package price MichaelV HVAC 3 12-02-2008 08:19 AM
