P-traps For A/C Condensate Lines. - HVAC - DIY Chatroom Home Improvement Forum
Old 07-18-2011, 11:40 PM   #1
JJboy's Avatar
P-traps for A/C condensate lines.
Do you install p-trap in positive and or negative pressure or just negative pressure system?
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-19-2011, 04:29 AM   #2
An old Tradesmen
Rewards Points: 7,770
I prefer to trap both.
The Following User Says Thank You to beenthere For This Useful Post:
JJboy (07-19-2011)
Low point in water supply lines dave11 Plumbing 3 02-01-2011 07:13 PM
slow hot water lines sobro Plumbing 3 11-05-2010 10:44 AM
Why move/replace heat pump refrigerant lines? EdLank HVAC 1 05-09-2010 05:02 AM
A/C condensate lines bounced HVAC 1 07-05-2009 04:02 PM
KNOWLEDGABLE condensate advice needed Nestor_Kelebay HVAC 5 11-23-2008 07:06 PM
