P-Trap - HVAC - DIY Chatroom Home Improvement Forum
Old 03-01-2011, 09:19 AM   #1
P-Trap
My AC instructions says to pour diluted Bleach or Vinegar into the P-Trap once monthly to deter Alge buildup. Where can I find the P-Trap on the unit?
clovis is offline   Reply With Quote
Old 03-01-2011, 09:35 AM   #2
Experienced
Jackofall1's Avatar
Welcome Clovis, to the best darn DIY'r site on the web.
I believe the "P" trap they are referring to is external to the expansion coil at the air distribution (furnace) device. The coil should be piped to a nearby drain, and trapped to seal off any air leakage.
Mark
Old 03-01-2011, 04:20 PM   #3
Just use the bleach in cooling season Clovis and a cap full is plenty. Bleach sitting in the trap without getting flushed by condensate fairly quickly is hard on coils. In cooling season the trap will be flushed with fresh condensate water after a few minutes of run time.
Old 03-02-2011, 06:27 PM   #4
Typically, it's the 3/4" PVC pipe, it comes out of your coils that are attached to your furnace. This line drains the condensation from the coils. The P Trap is a U shape in the line. In the line you may see a piece of PVC sticking up w/wo a cap. This is where you pour your bleach.
Poppyloppy is offline   Reply With Quote
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 11:46 AM
Keep cast iron trap or new ABS trap? thebigsee Plumbing 1 01-26-2010 03:18 AM
No drain trap in a 7-year old home - is this normal? curls00 Plumbing 2 12-05-2009 12:40 PM
Cat trap fever radtek General DIY Discussions 13 05-31-2009 06:18 PM
clogged pipe or trap issue? windowguy Plumbing 3 05-10-2009 10:10 AM
