Oxyquantum/ Kickstart - HVAC - DIY Chatroom Home Improvement Forum
Old 10-08-2012, 08:31 AM   #1
Rewards Points: 91
My Carrier unit is 6 months old. Just had service out for it's check up (clean, check pressures etc.) All is well.
Prior to leaving the service tech recommended I have 2 items installed. One is an Oxyquantum purifier which uses 2 UV bulbs which extend into the ductwork.
The other is a Kickstart.
He claims the Oxyquantum is a good thing to have in addition to filtration.
He further claims the Kickstart will prolong the life of my compressor.
I have researched both. Lights do not dim at startup and unit starts easily. Is the Kicikstart needed? If so looks like a simple DIY install. Not expensive if I buy on line and self install.
The Oxyquantum is very expensive! Actually I tried to find it online to see price and to see if I can DIY that as well. I cannot find it anywhere for purchase by homeowner.
Thoughts on these 2 items are welcome.
Are these just add ons that the service tech makes commission on or are they needed? If needed why not installed when unit was installed?
drjay9051 is offline   Reply With Quote
Old 10-08-2012, 12:27 PM   #2
Neither are needed. You likely have a tech on commission.
Old 10-08-2012, 03:12 PM   #3
does this help you any?
http://www.hrs72degrees.com/zNatures...ightOrders.php
Old 10-08-2012, 05:46 PM   #4
An old Tradesmen
Rewards Points: 6,132
Good chance your Carrier has a Copeland scroll compressor and doesn't need a hard start.
You don't really need an Ozone generator installed in your duct work.
http://www.4natureshome.com/uv_energy_UVV_ozone.html
UV lights can be beneficial, but if you didn't need one with your old system, you don't need one with your new system.
