Oversize Duct To Reduce Static Pressure? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-12-2010, 03:36 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
oversize duct to reduce static pressure?
Say I want to suck/push air in a duct run, will I get less static pressure if I increase the size of said duct run, and just use a reducer at the fan (so it fits properly)? Or will that make it worse, or make no difference?
Old 09-12-2010, 04:39 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
are you speaking inlet or outlet duct and are you altering the grill size as well?
Old 09-12-2010, 04:47 PM   #3
An old Tradesmen
Rewards Points: 7,362
IS this a return or a supply.
Old 09-12-2010, 07:13 PM   #4
Wire Chewer
Rewards Points: 126
This is for an inline bathroom fan, I need to go far with it. The fan would be near the end of the run, so most of it would be sucking action, and not pushing. It requires 4" duct but wondering if going 5" would reduce the static pressure. The inlet would probably be 5" too, one of those round adjustable ones. The fan connections would reduce to 4" then increase back to 5" to push the air out the house through a wall.
Old 09-12-2010, 08:35 PM   #5
An old Tradesmen
5" will reduce static pressure, and help you get closer tot eh fans rating.
Old 09-12-2010, 09:12 PM   #6
Wire Chewer
Rewards Points: 126
Good to know, that's what I figured. I also like the idea of using 5" to future proof the system. Maybe later on I'll want a bigger fan, or it breaks down and I can only find 5" ones, so I'll be set. I like the idea of having it in the basement more then the attic anyway, will be easier to service if required.
Static pressure question Red Squirrel HVAC 1 07-15-2010 06:23 AM
Can I reduce my AC CFM/ton to under 300 to lower static pressure? key1cc HVAC 34 06-02-2009 05:02 AM
Carrier 58MVC low static pressure alarm diy12345678 HVAC 1 11-06-2008 08:21 PM
Static Pressure: Rule of Thumb? rjordan392 HVAC 4 06-06-2008 12:55 PM
