Overly Dusty 5 Yr. Old House - HVAC - DIY Chatroom Home Improvement Forum
Old 02-26-2012, 11:31 PM   #1
Overly dusty 5 yr. old house
What can we do to cut down on the dust? House is 5 years old we chane the filters once a month and they are filthy? Hvac system is in the attic and ducts and returns are at the ceiling, on sunny days we can see the dust floating in the air. Windows are never opened, no construction in the neighborhood and the house is tight with door seals etc. Was told to put cheese cloth in the vent to block dust but will this block heat/ac getting in?
Angela Folding is offline   Reply With Quote
Old 02-26-2012, 11:35 PM   #2
Rewards Points: 13,694
Carpeted floors?
Running a humidifyer, getting rid of carpets. Will help keep the dust down.
They sell simple to install filter pads for you registers.
Old 02-27-2012, 12:11 AM   #3
how
Rewards Points: 1,104
My clients with the dustiest houses are usually the ones that are well sealed.
Humidity counts are often below 28% with drapes, upolstery, carpet, insulation, fabric etc breaking down.
I would get your humidity levels checked to see if you need a humidifyer connected to your heating system.
There is no way to know if cheesecloth will restrict too much of the airflow except by doing a temp rise check on your furnace. (it's easy to do). If the cheese cloth doesn't cause too much of a restriction on your system then spraying the cheesecloth with "Pam"will make it more effective.
What kind of filters are you now using and have you got your fan on 24/7?
how is offline   Reply With Quote
Old 02-27-2012, 04:30 AM   #4
An old Tradesmen
Rewards Points: 7,278
If duct work is in attic. Then it probably leaks, and the registers are not sealed to the sealing.
The Following User Says Thank You to beenthere For This Useful Post:
DangerMouse (02-27-2012)
Old 02-28-2012, 09:22 PM   #5
sktn77a's Avatar
Rewards Points: 392
What kind of filters are you using? If they are the inexpensive 1" fiberglass see-through filters then try a 4" Honeywell pleated filter that has the 1" lip to fit in your standard return grill.
sktn77a is offline   Reply With Quote
Old 02-28-2012, 11:33 PM   #6
Rewards Points: 152
If the return air ducts are in the attic and not sealed at the joints, would the system be pulling dusty air through from the attic?
burnt03 is offline   Reply With Quote
Old 02-29-2012, 04:07 AM   #7
An old Tradesmen
Yes it can.
Old 02-29-2012, 10:09 AM   #8
thermal-medics.com
BINGO
Run the a/c or heater and crack a door or window. Does the air blow in or out? I have opened customers door and almost had my hat blow off.
Guessing return duct leak with all the dust - air blowing out (door trying to close). door trick - might help you out
if not, like beenthere said - around the registers dust coming in
thermal-medics is offline   Reply With Quote
Old 02-29-2012, 10:37 AM   #9
Originally Posted by joecaption View Post
Carpeted floors?
Where? please give any info you have on them.
Hardway is offline   Reply With Quote
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 07:18 PM
Dusty House. Please help! X-Runner General DIY Discussions 13 12-04-2011 12:29 PM
Mast and weatherhead pulled from house, conflicting information from POCO subcontract SleepnZJ Electrical 1 11-02-2011 09:39 PM
Fixing weekend house staining that went awry jb888s Painting 10 08-17-2009 10:01 PM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
