Overhead Microwave Or Hood Exhaust - HVAC - DIY Chatroom Home Improvement Forum
Old 03-28-2013, 09:55 PM   #1
Overhead Microwave or hood exhaust
The house we live in has an overhead microwave with exhaust built in. The exhaust is basically useless and I hate having a microwave oven my stove. My wife and I have been thinking about switching to a hood exhaust. I was looking for an opinion on whether you think the switch is worth it? If so what do I need to know or look for when purchasing a hood exhaust system? Thanks for the help.
mhbrowns00 is offline   Reply With Quote
Old 03-28-2013, 10:42 PM   #2
Rewards Points: 12,802
Reason it may be useless in the filters plugged up or the plates in place so it's just recirulating the air instead of blowing it out the back or the roof.
Where do you plan in putting the microwave if it's not over the stove?
Old 03-28-2013, 10:48 PM   #3
Looking to get a countertop microwave and we have a nice area for it that isn't being used for anything else.
Old 03-28-2013, 10:50 PM   #4
chitownken's Avatar
Rewards Points: 510
I would say that the most important thing is the CFM rating of the fan. The more smoke / cooking odors you want to exhaust the higher the CFM rating needs to be. A lot depends on your stove / cooktop. Our has a grill built into the center and requires a minimum 750 CFM fan to handle. Works ok for steaks but can't keep up with the smoke from grilling brats. Think about what you cook and go from there. I would guess that 250 - 300 CFM would be about the minimum for an effective vent hood. You should also make sure that you can vent the exhaust to outside the building.
chitownken is offline   Reply With Quote
The Following User Says Thank You to chitownken For This Useful Post:
mhbrowns00 (03-29-2013)
Old 03-29-2013, 04:08 PM   #5
Rewards Points: 1,214
I agree with Joe post #2 . I would check everything before canning the Micro/Hood generally they work very well and have good exhaust speeds. Find the installation manual and make sure the fan is installed in the right exhaust position(most have a couple settings) up thru the roof, out the back, recirculate. Also check the filters as Joe said.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Tags
exhaust hood , hood , overhead microwave , range exhaust
Replacing old hood with over-the-range microwave Nathan0115 Electrical 21 07-27-2012 04:37 PM
Running an over exhaust hood off a recepticale Snowdog1975 Electrical 2 01-30-2012 04:16 PM
Fume Hood Exhaust RomanDesign Appliances 6 01-06-2011 03:34 PM
Hood / Microwave Exhaust Vent, Wall question tameanaka Building & Construction 5 09-21-2010 03:44 PM
DIY exhaust hood for grill sidewayzisbest Appliances 1 09-30-2009 08:51 PM
