Overcharging An Ac Unit - HVAC - DIY Chatroom Home Improvement Forum
Old 07-21-2012, 12:41 AM   #1
Post
overcharging an ac unit
can you explain what cause the pressure to rise on the low and high side when you overcharge an ac unit.
astovall7 is offline   Reply With Quote
Old 07-21-2012, 01:35 PM   #2
Ah where to began...
Compressor is the pump the low side is the suction and the high side is the discharge. The discharge flow freely to it meets the metering device at the indoor coil. The metering device causes a designed restriction. This restriction causes a change of state and temperature. The low temperature low pressure refrigerant then travels back to the compressor where it is pumped back to a high pressure high temperature gas and is sent to the condenser (outside) coil where it is condensed into a liquid again and sent to the indoor unit again.
Add to much refrigerant and the pressures on both sides rise until you get a flooded evaporator which is a whole other matter....
turnermech is offline   Reply With Quote
Old 07-21-2012, 04:35 PM   #3
biggles's Avatar
once the liquid line is formed out of the condenser anything over that 2 or 3 rows from the bottom takes up condenser area and the ejection of the heat from that discharge gas from the compressor.everything follow up by rising..head,liquid ine pressure and right into that suction.then the suction being 75PSI or above you lose the temperature to make the indoor coil drop the room air...a dirty condenser on a normal charge will cause the same effect...never charge a unit with a dirty condenser always clean it first with the guages on to see the cleaning results in pressure drop
Old 07-21-2012, 08:22 PM   #4
Missouri Bound's Avatar
Homework??
Do you want it your way or the right way?
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 10:11 AM
Had an Aire-Flo AC installed, looking for opinions mikemcd HVAC 14 08-01-2011 04:07 AM
new r-410a ac unit installation procedure(w/old unit r-22)? excalibur1 HVAC 0 06-06-2011 03:47 PM
Window A/C Unit and Supplying Power JayEnder Electrical 1 04-30-2011 07:50 PM
Inside Unit Runs, Outside Unit Runs (with help) no cold air beakon20 HVAC 4 08-13-2008 09:33 PM
