Over heated house
Why does my Burnham oil fired boiler that heats hot water for domestic use and to circulate thru baseboard raditors to heat the house cause the house to be kept at a higher temperature than the programable thermostat is set for?
Could be that the thermostat is bad, o hat a flow control valve(flow check) is leaking through.
| All times are GMT -4. The time now is 10:48 AM. |
