Outside Unit Of Heatpump Keeps Running - HVAC - DIY Chatroom Home Improvement Forum
Old 07-27-2011, 12:18 AM   #1
outside unit of heatpump keeps running
Forgive the dummy here. The inside blower unit turns off at the appointed temp but the outside unit continues to run making a labored noise. I suspect a relay is stuck. When I tap the outsde unit with my fist it turns off. Is this a switch or relay problem? If so where would I find it and is this a DIY repair? Thanks , Bill
budyboy is offline   Reply With Quote
Old 07-27-2011, 12:32 AM   #2
JJboy's Avatar
Check the contactor.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Carrier Central Heat/Air Unit acting strangely TheWilldog HVAC 4 02-16-2011 07:42 PM
Outside Unit Not Running chris1381 HVAC 3 08-24-2010 07:22 AM
Why is Inducer Fan Running? artbuc HVAC 3 07-31-2010 10:39 AM
compresser unit running ok, try's to restart Pat33019 HVAC 2 09-26-2009 12:44 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 02:46 PM
