Outside Unit Frozen - HVAC - DIY Chatroom Home Improvement Forum
Old 01-16-2013, 11:27 AM   #1
Rewards Points: 123
Outside unit frozen
My outside unit has frozen up. Is this a sign of low refrigerant or defrost mode not working? It has rained here nontstop for 5 days. Outside temp is around 45 degrees.
Thanks,
Chris
poolecw is offline   Reply With Quote
Old 01-16-2013, 12:03 PM   #2
It could be either, however from looking at it the freeze pattern seems a little wierd which could be because of low freon. Because when freon is low you get a lower temp where the freon first enters the coil. So what can happen is it freezes just at the inlet of the coil. It looks like most of your coil is extremely clear, units not going into defrost tend to freeze more evenly.
However some units use what is called a "demand defrost" and they can leave ice rings like that, but yours seems too thick for that to be the case, but it's still possible.
JScotty is offline   Reply With Quote
Old 01-16-2013, 12:32 PM   #3
Looks like a restriction in the distributor tubes feeding those rows.
Old 01-16-2013, 01:04 PM   #4
Rewards Points: 123
I was able to get a better look at it during lunch today. It begins freezing up as the line comes into the unit. I think the reversing valve may be stuck but I really don't know. I've got someone coming out tomorrow to check it out.
Thanks for the input.
Thanks,
Chris
Old 01-21-2013, 09:05 AM   #5
Rewards Points: 123
Ok, I had my HVAC tech come out. The problem was the defrost thermostat switch wasn't working. He got the freon down to -10 degrees and it wouldn't ever swith on. He forced it into defrost mode and verified that defrost mode would work.
Thanks,
Chris
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 11:11 AM
Newbie attempting to replace an old condensing unit (please help) samboy HVAC 2 08-14-2012 05:21 PM
Replace just the Cooling Unit for Condo HVAC System acj74 HVAC 19 07-22-2012 03:03 PM
Had an Aire-Flo AC installed, looking for opinions mikemcd HVAC 14 08-01-2011 05:07 AM
new r-410a ac unit installation procedure(w/old unit r-22)? excalibur1 HVAC 0 06-06-2011 04:47 PM
