Outside Unit Freezing. - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-20-2010, 07:17 PM   #16
An old Tradesmen
Rewards Points: 7,270
Originally Posted by wetbar View Post
"The compressor, liquid line filter drier(if its outside), and accumulator will all have refrigerant in them after you recover.. "
Even if the guages show 20 or 30 vacuum?
Yep.
Its boiling that slow. that your pump will be pulling that low that your gauges will read that. And shortly after you shut the pump off. the refrigerant will boil off enough to produce what ever X pounds of pressure.
I run into it a lot working on heat pumps, or cooling systems that need to run year round.
Can't get unit to turn on need electrical help please-wiring diagram included igotshocked Electrical 33 01-30-2014 05:13 AM
Deck Landing and A/C Unit Master Brian HVAC 10 07-22-2010 07:08 PM
AC condensing unit failure? Hotinsummer HVAC 3 08-09-2009 02:08 PM
Central Air Unit is freezing up, all fans working rebuildergirl HVAC 3 06-08-2009 08:42 PM
central unit will not come on ....please help guyasc HVAC 5 08-24-2008 05:10 PM
