Outside Unit Fan Wont Work Randomly, Help - HVAC - DIY Chatroom Home Improvement Forum
Old 01-11-2009, 05:09 PM   #1
Outside unit fan wont work randomly, help
Hello, my carrier outside unit fan works perfect most days, but then they are times that the fan doesnt kick on at all, but the compressor does and some times the fan doesnt kick on at first but 30-45 secs later the fan comes on.Ive replaced the contactor switch and the dual run capacitor and that didnt fix the problem. The fan motor turns easily as well. Any suggestions on what it may be ? Thanks for you time.
jlsk8ter is offline   Reply With Quote
Old 01-11-2009, 05:18 PM   #2
replace the capacitor (they are cheap enough) if you still have the same problem the motor may have a dead spot. when this happens again try pushing the the fan (not with your hand) to see if you can jumpstart it. You may need to replace it.
thelimit is offline   Reply With Quote
Central Air Outside Unit Cover czars HVAC 2 01-07-2009 10:23 PM
Electric question from power pole to unit Slocalaman Electrical 3 11-06-2008 03:23 PM
Heat Pump/AC not cooling, new home eshipler HVAC 7 07-25-2007 08:52 PM
Used Central Air Unit? shep28 HVAC 2 04-21-2007 07:59 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
