Outside Heat Pump Fan Rotation - HVAC - DIY Chatroom Home Improvement Forum
Old 12-08-2009, 12:53 PM   #1
outside heat pump fan rotation
Should the fan rotate clockwise or counter clockwise? just not sure which way its supoose to spin.
So should air be pushing out the top of heat pump or being pulled in? I assume it should be pushed out thru the top.
jeff
jwalker95 is offline   Reply With Quote
Old 12-08-2009, 05:00 PM   #2
Blows out the top .
Old 12-09-2009, 05:40 AM   #3
thanks.
heat pump cut off set point oldswab HVAC 4 12-02-2009 02:09 PM
Water Source Heat Pump installation JLMitchell HVAC 6 11-30-2009 03:23 AM
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 03:05 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
