Outside Gas Line Shutoff - HVAC - DIY Chatroom Home Improvement Forum
Old 02-07-2011, 06:54 PM   #1
outside gas line shutoff
Hi i purchased a house recently and the gas line going into the garage is shut off.I noticed that there is a hole to lock it out but when i try to turn it to the on position it will not move could it be that it is frozen because where i am it is -24 today and a couple of days ago it was +4 with some rain then the next day it became freezing? Should i try to force it open or will i cause damage?
princeofpain is offline   Reply With Quote
Old 02-07-2011, 06:55 PM   #2
HVAC / Plumbing
does this valve belong to you or the gas co. ?
kenmac is offline   Reply With Quote
Old 02-07-2011, 06:58 PM   #3
It comes from my house underground to the outside of my garage
Old 02-07-2011, 07:01 PM   #4
The previous owner told me he turned it off because he took the old heater
Old 02-07-2011, 07:02 PM   #5
HVAC / Plumbing
If it's old . It could be just hard to turn. The gas co. in my area have replaced most of their hard to turn valves with easy to turn ball valves. I have had to use a 18'' pipe wrench to turn some of those valves
Old 02-07-2011, 07:03 PM   #6
It was put there in 2006
Old 02-07-2011, 07:06 PM   #7
HVAC / Plumbing
If it were me. I would use a larger wrench. If you aren't comfortable with doing this. I suggest you call a plumber
Old 02-07-2011, 07:09 PM   #8
Thanks i'll try that
Old 02-07-2011, 09:38 PM   #9
HVAC Supermodel
unicursalhex's Avatar
Rewards Points: 150
Pour some warm water over it, I do this all the time during winter.
unicursalhex is offline   Reply With Quote
Old 02-07-2011, 09:42 PM   #10
Thanks the warm water worked....
Old 02-07-2011, 09:43 PM   #11
Experienced
Jackofall1's Avatar
I thought that was for dogs....
Get a 24" pipe wrench, that should persuade it to move.
I would be more concerned as to why the owner turned it off, please check all gas lines in the house to make sure there is no open line or valve!
Mark
New ICe maker line causes ice to taste like rubber speedster1 Plumbing 5 06-27-2010 08:09 AM
Capacity loss with line size Einride HVAC 1 06-29-2009 03:10 PM
Add natural gas line Tukeeman Plumbing 11 12-01-2008 07:53 AM
electric line and gas line couch potatoe Electrical 17 09-30-2008 10:43 PM
Condensate Line schott HVAC 17 06-02-2008 03:16 PM
