Outside Fan Not Coming On. - HVAC - DIY Chatroom Home Improvement Forum
Old 07-01-2011, 09:21 AM   #1
Rewards Points: 41
Outside Fan not coming on.
There is air coming thru the vents in the house, but the fan on the unit outside is not coming on. (So no cool air)
I can turn the breaker off, give the fan a good spin, and turn the breaker on and everything works for about 15 minutes... then stops again.
Went thru this a year ago, and it ended up being the Capacitor. It looked like a soda can about to explode. Capacitor doesn't look like that now.
Thanks for any and all advice!
dbower is offline   Reply With Quote
Old 07-01-2011, 02:29 PM   #2
JJboy's Avatar
Bad capacitor.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-01-2011, 02:45 PM   #3
Rewards Points: 41
Had a tech come out. He checked the Capacitor, and said it was good. Thinks its the fan motor.
The Fan came back on, and stayed on... so decided not to replace the motor at this point.
Old 07-01-2011, 03:04 PM   #4
Rewards Points: 338
when the unit is off, check to see if the fan spins freely (use a stick or something to spin the fan). if there is any resistance, the bearings could be going bad. I had a similar problem about 3 years ago and believe it or not, a little WD-40 did the trick. you have to remove the fan assembly, turn it over and spray the lubricant on the underside where the shaft goes up into the motor. this is not a permanent fix by any means, you may get a few months or you may get a few years out of it like me.
NitroNate is offline   Reply With Quote
Old 07-01-2011, 03:08 PM   #5
Rewards Points: 41
No, the fan spins freely. And after spinning, I can turn power back on... and fan will spin.
Had a tech come out. Said the Condenser is good. Maybe the motor is going out.
Old 07-01-2011, 03:49 PM   #6
An old Tradesmen
Rewards Points: 7,414
Did he test the capacitor with a meter, or just look at it.
Old 07-01-2011, 04:05 PM   #7
Rewards Points: 41
He used a meter.
Old 07-05-2011, 12:17 PM   #8
Rewards Points: 41
Its definitely the fan motor. Debating whether to fix it myself, or pay the tech. They want $350 to do it.
Any suggestions where to buy a replacement motor in Fort Worth area?
Old 07-05-2011, 03:34 PM   #9
JJboy's Avatar
On line.
Fire ants coming into house through pipes in foundation -- need advice samalex Pest Control 15 03-22-2011 01:35 PM
Heat only coming from a few vents? MyZoeJane HVAC 4 02-09-2011 04:04 PM
if there are red white green and black wires coming out of your walls like everywhere cray331 Electrical 3 01-17-2011 12:56 PM
washer and Clothes coming out of washer stink. rsplash40 Appliances 11 07-03-2009 11:05 AM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
