outside fan/ air condenser is constantly on, I pulled the fuse block that shut off the power to the unit, heater under the house works fine, but my question is, how long can i run my heater with out my "outside fan" NOT turned on with the heater (furnace) on....???
Goodman manufacturing
model# - CPKE30-1B
pn- 14930-75
sn- 9902400789
am i going to ruin anything if i have my heater turned on without my " outside heat pump" turned on??
how would i know if i have a bad or stuck relay??
THANK YOU!!
FIXED!!!
Contractor, okay thanks, looked at it, i had one weird looking relay bundle hooked up and one of the wires was actually touching a yellow wire, separated them, put the fuse block back in, didn't turn on, WORKS NORMAL....OR AS ADVERTISED
model# - CPKE30-1B
pn- 14930-75
sn- 9902400789
THANK YOU!!
FIXED!!!
