-   -   outside fan constantly on.. pulled fuse block...help (http://www.diychatroom.com/f17/outside-fan-constantly-pulled-fuse-block-help-92457/)
AlexnBeth 01-16-2011 08:51 AM
outside fan/ air condenser is constantly on, I pulled the fuse block that shut off the power to the unit, heater under the house works fine, but my question is, how long can i run my heater with out my "outside fan" NOT turned on with the heater (furnace) on....???
Goodman manufacturing
model# - CPKE30-1B
pn- 14930-75
sn- 9902400789
am i going to ruin anything if i have my heater turned on without my " outside heat pump" turned on??
how would i know if i have a bad or stuck relay??
THANK YOU!!
FIXED!!!
Contractor, okay thanks, looked at it, i had one weird looking relay bundle hooked up and one of the wires was actually touching a yellow wire, separated them, put the fuse block back in, didn't turn on, WORKS NORMAL....OR AS ADVERTISED
yuri 01-16-2011 09:09 AM
Is it a heat pump. Post the make and model # and serial #.
beenthere 01-16-2011 11:46 AM
Yes, please post brand and model number of both the outdoor and indoor unit.
If its a heat pump, your thermostat may be one of the ones that keeps a heat pump running 24/7 after it gets X cold outside. And by shutting it off your now running on the expensive electric aux heat.
LukeROttinger 01-16-2011 11:53 AM
you may also want to check that you don't have a stuck relay
AlexnBeth 01-16-2011 04:55 PM
model# - CPKE30-1B
pn- 14930-75
sn- 9902400789
thank you guys for your help, tomorrow i will be crawling under the house to check any relays,
THANK YOU!!
beenthere 01-16-2011 05:17 PM
turn your thermostat to emergency heat. turn the stat up several degrees higher then the room temp. then turn the power back on to your outdoor unit. If it doesn't run, then its not a stuck relay.
AlexnBeth 01-16-2011 07:52 PM
DID IT,:thumbsup: it ran in emergency mode,
so how do i figure out where and what relay?
where and what could i be looking for?
would it be in the (outside) heat pump?
or
on the furnace unit it self?
beenthere 01-16-2011 09:18 PM
Probably in the outdoor unit. Probably the contactor.
AlexnBeth 01-17-2011 06:44 AM
Contractor, okay thanks, looked at it, i had one weird looking relay bundle hooked up and one of the wires was actually touching a yellow wire, separated them, put the fuse block back in, didn't turn on, wow you guys rock! thank you for your help!!!
