Outside Controller Switches - HVAC - DIY Chatroom Home Improvement Forum
Old 09-05-2010, 01:12 PM   #1
outside controller switches
The outside compressor spring loaded controller swich located under a metal protective cover became stuck and included failure of a air handler breaker. The same switch on another unit remains in the compressed position, and there is 27 volts flowing to the controler tranformer engaging the spingloaded switch yet the main breaker is off to the unit. The units are Lennox models
12ACB30-5P - Current flowing to switch, switch is depressed
12ACB48-5P - Blown air handler fuse, switch removed and freed of restricted movement.
Wiggytiger is offline   Reply With Quote
Old 09-05-2010, 02:29 PM   #2
That part is called a contacor. There's high voltage on an AC that comes from the breaker and ther's low voltage that comes from the furnace/air handler. Didn't see a question in there but hopefully that answers what you need to know.
Old 09-05-2010, 02:31 PM   #3
An old Tradesmen
Rewards Points: 8,170
I read it twice. And don't see a question.
Question about wiring and voltage with switches and lights rswurth Electrical 17 06-20-2010 11:12 PM
Question about switches on a 20 amp circuit Abs777 Electrical 6 04-28-2010 10:09 AM
Replacing switches turning into nightmare. RyanD Electrical 19 05-26-2009 06:19 PM
light switches wired in series -- why? magnolia Electrical 2 05-11-2008 11:16 AM
Need help replacing switches in four-way circuit magnolia Electrical 3 05-09-2008 09:40 PM
