Outside Condensing Unit Not Working - HVAC - DIY Chatroom Home Improvement Forum
Old 05-06-2010, 12:02 PM   #1
Unhappy
Outside Condensing Unit not working
I have the exact same condensing unit as g8tkeeper. My problem is a bit different. The compressor and fan both start at the same time and I do feel the cold air as the outside unit is running. However, after about 2 minutes, the fan and the compressor shut off then turn back on after about 5 minutes. I have the exact same capacitor as g8tkeeper and there are no visible bulges like he had demonstrated in his pictures. The fan runs fine, there are no noises, it doesn't wobble or anything. Do you think I should replace the both items as stated by g8tkeeper? Any other suggestions to trouble-shoot this problem will be very helpful.
Will B is offline   Reply With Quote
Old 05-06-2010, 04:15 PM   #2
not sure of what type of unit you have, but it sounds like it is going off on a low pressure switch than coming back on after the pressure rises. Sounds like its low on refrigerant
kennzz05 is offline   Reply With Quote
Old 05-06-2010, 05:48 PM   #3
Agreed. Sounds like you have a leak and are going to need a real repair man. Be forewarned it's probably going to be expensive.
Old 05-07-2010, 07:11 AM   #4
My unit is a Carrier/Puron model# 38EYG048301. It was filled with freon/refrigerant about 6 months ago and I know that a leak could have developed by then.
Thanks for the forewarning!
Tags
capacitor , compressor , condensing unit
Heil 5000 HE unit not working oldtom HVAC 2 09-27-2009 08:27 PM
AC condensing unit failure? Hotinsummer HVAC 3 08-09-2009 03:08 PM
new hvac precharged unit install reno1011998 HVAC 1 01-30-2009 03:37 PM
Central Air Outside Unit Cover czars HVAC 2 01-07-2009 11:23 PM
Electric question from power pole to unit Slocalaman Electrical 3 11-06-2008 04:23 PM
