Outside A/C Unit Won't Kick On - HVAC - DIY Chatroom Home Improvement Forum
Old 04-20-2009, 07:31 PM   #1
Outside A/C unit won't kick on
Hey guys, my outside unit(heat pump?) will not turn on, the inside temp is at 82, I set it for 76 but nothing happens, I walked outside after reseting the therm. again to 76 and i hear a sound from the unit like it is going to turn on but it just quits, is it possible that the fan in the unit has seized up? i tried using the heat and I feel hot air coming from the vents. any ideas guys
zosoplumber is offline   Reply With Quote
Old 06-01-2009, 10:56 AM   #2
I had the same problem, turns out it was the capacitor that was blown. According to the AC Tech, the capacitor can go bad if the freon is low and/or you have the AC set really low. Either way, the unit has a history of losing freon and adding fron and replacing the capacitor fixed the issue.
neo_mra_ct is offline   Reply With Quote
Can't get unit to turn on need electrical help please-wiring diagram included igotshocked Electrical 33 01-30-2014 06:13 AM
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 11:11 AM
Central Air Outside Unit Cover czars HVAC 2 01-07-2009 11:23 PM
central unit will not come on ....please help guyasc HVAC 5 08-24-2008 06:10 PM
Wall unit AC drips water inside fw2007 HVAC 4 08-15-2008 11:07 AM
