Old 02-03-2008, 04:19 PM   #1
Outside Blower wont turn off
Unit wont turn off, but switch appears to disconnect. Blower just runs all of the time. Is there a way to adjust or reset the panel?
Help!
seanbryant is offline   Reply With Quote
Old 02-03-2008, 04:45 PM   #2
biggles's Avatar
the condenser fan motor on the compressor/condenser section outside your home.if the stat is not set for COOLING and if it's not a HEAT PUMP for heating the house ,,,walk out and shut off the disconnect at the condenser and call for service something is going on inside the unit.if it is a HEAT PUMP it should run when it is heating the house then don't touch it.
Old 02-06-2008, 09:23 PM   #3
Angry
Thank you for the obvious!
What I'm trying to find out is why the fan wont stop blowing....EVER! Even when the thermostat is in the "off" mode, it runs. When its in the on or auto mode it runs. It NEVER turns off! Why?
What could possibly cause this? I dont understand!
Frustrated!
Old 02-07-2008, 05:10 PM   #4
biggles's Avatar
if the condenser fan is running it comes off the same control asthe compressor which is a problem with in the condenser...call for an electrican or local neighbor who knows electrical to isolate the problem.DO NOT TOUCH THE CONDENSER COULD GET SHOCKED!
Comfortmaker blower intermittent problem jh44ny HVAC 12 07-31-2011 07:41 PM
Heat comes on but blower never does aczer HVAC 12 02-13-2011 07:57 AM
Blower control board mlmaher HVAC 1 11-24-2007 02:39 PM
Induction blower seal ktritz HVAC 4 03-05-2007 09:52 PM
My blower won't turn off, either Charmed HVAC 2 01-25-2007 12:02 PM
