-   -   Outside Blower wont turn off (http://www.diychatroom.com/f17/outside-blower-wont-turn-off-16558/)
seanbryant 02-03-2008 04:19 PM
Unit wont turn off, but switch appears to disconnect. Blower just runs all of the time. Is there a way to adjust or reset the panel?
Help!
biggles 02-03-2008 04:45 PM
the condenser fan motor on the compressor/condenser section outside your home.if the stat is not set for COOLING and if it's not a HEAT PUMP for heating the house ,,,walk out and shut off the disconnect:yes: at the condenser and call for service something is going on inside the unit.if it is a HEAT PUMP it should run when it is heating the house then don't touch it.:no:
seanbryant 02-06-2008 09:23 PM
Thank you for the obvious!
:thumbsup:
What I'm trying to find out is why the fan wont stop blowing....EVER! Even when the thermostat is in the "off" mode, it runs. When its in the on or auto mode it runs. It NEVER turns off! Why?
What could possibly cause this? I dont understand!
Frustrated!
biggles 02-07-2008 05:10 PM
if the condenser fan is running it comes off the same control asthe compressor which is a problem with in the condenser...call for an electrican or local neighbor who knows electrical to isolate the problem.DO NOT TOUCH THE CONDENSER COULD GET SHOCKED!
