Outside Air Conditioner - HVAC - DIY Chatroom Home Improvement Forum
Old 06-17-2011, 11:47 AM   #1
outside air conditioner
Please compare a trane airconditioner to a payne airconditioner?
badger24 is offline   Reply With Quote
Old 06-17-2011, 02:01 PM   #2
Willing to listen
Rewards Points: 215
Find a great installer by talking to your friends, neighbors, coworkers etc and don't worry so much about the brand.
Payne is a Carrier brand. Maybe the biggest difference between Carrier and Trane is Trane using aluminum spine fin for the outdoor coil instead of more traditional copper tubes. And each of these has their pros and cons...
Done That is offline   Reply With Quote
Old 06-17-2011, 02:15 PM   #3
Rewards Points: 392
What are those pros and cons?
zootjeff is offline   Reply With Quote
Old 06-17-2011, 02:29 PM   #4
Willing to listen
Rewards Points: 215
One persons view of a pro is anothers idea of a con...so take it with a grain of salt...
Aluminum supposed to be less likely to leak, not as many joints...it's one continious piece. Some don't like cleaning the spine fin especially if it gets gunked with cottonwood or the like....but I suspect the guys who work on Trane all the time have it figured out. Some of the higher efficiency Tranes are two row spine fin so maybe a bit harder still to clean. More folks in the field probably know how to repair a leak in copper than aluminum. Trane would probably argue it has better (more) surface area and therefore improved heat transfer. I'm sure there's more....
I would take either one if I felt good about the guy putting the equipment in. I do prefer units with some type of coil protection/hail guard which both brands offer.
Old 06-17-2011, 02:57 PM   #5
Rewards Points: 6,652
What are you asking pertaining to the name, or installation. Over and over, it has been stated that a system is only as good as the person installing and maintaining it. Names really mean nothing.
New Air Conditioner trips breaker Cano Electrical 4 07-11-2010 11:29 AM
Heat pump vs. Furnace and Air Conditioner heating&cooling HVAC 11 06-16-2010 07:07 PM
air conditioner tripping at current interrupter donny.frankrice HVAC 10 07-07-2009 03:08 PM
Installing window air conditioner mary60 Electrical 1 08-14-2008 07:25 PM
window unit air conditioner help? greenvorlon Appliances 1 08-03-2007 12:50 PM
