Outside AC Unit Not Turning On - HVAC - DIY Chatroom Home Improvement Forum
Old 06-06-2012, 02:44 PM   #1
outside AC unit not turning on
have a Ducane unit outside.(4ac13L30p) The first time this year I went to use the AC, the fan inside kicks on and blows the air around but the house wasnt cooling. I went outside and the unit isnt doing anything. Fan hasnt moved, no humming, ect. Its only a few years old. I reset the breaker. I opened up the outside unit and pushed the button and it didnt power on. There is power going into the button, and also when I press the button there is power on the other end at the connections on the button. Wires all look good, no fraying or broke wires... Any thoughts or suggestions? Start up Capacitor?
rgall is offline   Reply With Quote
Old 06-06-2012, 04:04 PM   #2
biggles's Avatar
what button are you pushing are there fuses in the disconnect for the condenser?
Old 06-06-2012, 04:35 PM   #3
Perhaps check this link out (about contactors): http://brokenthermostat.com/Troubles...ontactors.html
TopTechnician is offline   Reply With Quote
Old 06-06-2012, 04:57 PM   #4
I dont see any fuses. There is a button on the outside unit by the start up capacitor, where all the wires go into the outside unit and if everything is workin, when you push it the unit should power on. It may be a relay. Power comes into it and goes out. No power goes out until I push the button in which is what I told is how this is suppose to work...
Old 06-06-2012, 05:28 PM   #5
REP
Sounds like a bad contactor.Label ALL the wires,remove from contactor,take said contractor to I.E. Graingers ,get an exact replacement and install.
Don't forget to shut off ALL power by switching the3 main breaker off before touching any of the wires.
REP is offline   Reply With Quote
Can't get unit to turn on need electrical help please-wiring diagram included igotshocked Electrical 33 01-30-2014 05:13 AM
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 10:11 AM
HAVC unit won't come on atlacfence HVAC 0 05-06-2012 09:48 AM
Need advice outside unit not working 337ram HVAC 18 03-26-2012 05:23 PM
York AC unit outside not turning on ssssg1 HVAC 1 07-25-2006 08:30 PM
