Outlet Temp - HVAC - DIY Chatroom Home Improvement Forum
Old 11-11-2012, 05:27 PM   #1
Outlet temp
What would you expect the furnace outlet temp,measured right above the A coil, to be on my Goodman natural gas fired unit rated at 80,000 btu
Mule98 is offline   Reply With Quote
Old 11-11-2012, 06:03 PM   #2
raylo32's Avatar
Rewards Points: 1,226
Deleted duplicate post. What is up with this website today???
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 11-11-2012, 06:05 PM   #3
raylo32's Avatar
Outlet temp is the wrong measurement. You should check the temp differential between the return and the supply plenums. I am not sure of your exact model but the specs are generally something like 40-60 degrees F difference which depends a lot on the fan speed jumper setup.
Old 11-11-2012, 06:34 PM   #4
I'm Your Huckleberry
Rewards Points: 2,270
Originally Posted by raylo32 View Post
deleted duplicate post. What is up with this website today???
arrrrrgggggg!!!!!
Thanks.
Doc Holliday is offline   Reply With Quote
Old 11-11-2012, 06:34 PM   #5
No kidding. It's been kicking me off or not finding the page and all types of crud today.
Very slow as well.
Thanks.
Old 11-11-2012, 09:52 PM   #6
Rewards Points: 614
furnace will say somewhere the allowable temperature rise....if you want the heat exchanger to last do not exceed it.......
carmon is offline   Reply With Quote
Outdoor Outlet seansy59 Electrical 3 03-09-2012 04:50 PM
Swithced Outlet to Ceiling Light/Fan Troubles adamiano86 Electrical 7 01-29-2012 10:36 PM
GFCI outlet failed in a rain storm, now has no power! Kaybee33 Electrical 5 12-28-2010 06:38 PM
Switched outlet series Overkll Electrical 4 12-07-2010 08:38 AM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 09:38 PM
