-   -   Outlet temp (http://www.diychatroom.com/f17/outlet-temp-162979/)
Mule98 11-11-2012 05:27 PM
Outlet temp
What would you expect the furnace outlet temp,measured right above the A coil, to be on my Goodman natural gas fired unit rated at 80,000 btu
raylo32 11-11-2012 06:03 PM
Deleted duplicate post. What is up with this website today???
raylo32 11-11-2012 06:05 PM
Outlet temp is the wrong measurement. You should check the temp differential between the return and the supply plenums. I am not sure of your exact model but the specs are generally something like 40-60 degrees F difference which depends a lot on the fan speed jumper setup.
Doc Holliday 11-11-2012 06:34 PM
Originally Posted by raylo32 (Post 1049814)
deleted duplicate post. What is up with this website today???
arrrrrgggggg!!!!! :)
No kidding. It's been kicking me off or not finding the page and all types of crud today.
Very slow as well.
carmon 11-11-2012 09:52 PM
furnace will say somewhere the allowable temperature rise....if you want the heat exchanger to last do not exceed it.......:eek:
